Discussion topic: Cannot link my sky q box with the mini box, message on home screen is do not have internet connecti
Message posted on 12 Aug 2024 05:45 PM
Have this message on both screens but still getvall tv setvices through main Q box
Message posted on 12 Aug 2024 05:48 PM
Re: Cannot link my sky q box with the mini box, message on home screen is do not have internet conn
Hi @DaveC5
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
Message posted on 12 Aug 2024 06:09 PM
Hi Oldfella
Ill try this,my gut feel is thag i need a replacement mini box, but Ill also try and speak to Sky tomorrow (have you tried to spezk to a human at sky on 150) as i have a fault code on the 2nd TV connected to the mini box
DaveC5
Message posted on 12 Aug 2024 06:18 PM
@DaveC5 wrote:
Hi Oldfella
DaveC5
Hi @DaveC5
If one mini is connected you could try swapping the two minis round.
