Discussion topic: Cannot get sky sports or other sky channels for weeks now
Message posted on 23 Jul 2023 08:58 PM
Message posted on 23 Jul 2023 09:02 PM
Re: Cannot get sky sports or other sky channels for weeks now
What is happening when you try? What have Sky said when you reported this to them?
Message posted on 23 Jul 2023 09:05 PM
It says satellite issue, but have some of the channels?
Message posted on 23 Jul 2023 09:08 PM
@SU51DEM
No signal normally comes from your TV, no satellite signal normally refers to your Sky box. Have a look at this link
https://www.sky.com/help/articles/sky-tv-no-satellite-signal
If that doesn’t help you, at the end of the link it should give you an option to arrange an engineer to check your dish alignment.
