Discussion topic: Cannot get sky remote to connect to tv since i changed my wifi hub
This message was authored by: Angel1929
I cannot get the sky remote to connect to sky q box since ive changed the wifi code?
Re: Cannot get sky remote to connect to tv since i changed my wifi hub
Hi @Angel1929
First reboot the Q box.
If you had to press the Standby button on the Q front of the Q box to switch it on
