Discussion topic: Cannot get a connection on my bedroom sky box. Followed Sky instructions to rectify the problem , b
This message was authored by: Graham19671
In the previous statement, I am unable to establish a connected to my Sky box in our bedroom. I have followed Sky instruction , but still no Sky in our bedroom..
Re: Cannot get a connection on my bedroom sky box. Followed Sky instructions to rectify the problem
Hi @Graham19671
Reboot the mini as above.
