Discussion topic: Cannot get TV schedule via mini box, have reset main Sky Q box, the Sky router and the mini box
This message was authored by: Wil+Bo
No TV schedule via mini box, have reset main Sky Q box, the Sky router and the mini box still not working. All connections via setting show as working normally, have reset connections but still not working, suspect the mini box has failed as the TV schedule is working normally via the main Sky Q box.
Re: Cannot get TV schedule via mini box, have reset main Sky Q box, the Sky router and the mini box
Hi @Wil+Bo
Try a Reset Settings in the main Q box hidden menu.
If the mini still does not show correctly tben carry out a Reset Settings in the mini hidden menu.
After the reset you will have to re pair the mini remote.
Avatar for Wil+Bo
Hi, thank you for your reply.
I have tried that and the reset on the mini box.
It is still showing,"waiting for TV schedule,"
In settings it is showing as connected to the Sky Q box, the broadband and the internet.
I can also play any recordings?
