Discussion topic: Cannot connect to Sky on my Samsung TV...message reads 'weak or no signal... check the aerial cable
This message was authored by: Tony3105
Message posted on 17 Jul 2024 05:57 PM
I have checked aerial cable connection - OK - don't know how to 'check saved channels'
Find out more
Message posted on 17 Jul 2024 06:08 PM
Re: Cannot connect to Sky on my Samsung TV...message reads 'weak or no signal... check the aerial ca
@Tony3105 that message has nothing to do with Sky it is a message from your TV in relation to the freeview channels available when you connect an actual aerial to the TV and not your Sky box
