Discussion topic: Cannot connect internet to Sky q box. The internet is working on other devices. Sky mini won’t work
Message posted on 23 Mar 2024 09:47 AM
Cannot connect internet to Sky q box. The internet is working on other devices. Sky mini won’t work Because the sky q box won't connect to the internet. I have in plugged both devices and re set the internet. I have also tried to connect manually with the password.
Message posted on 23 Mar 2024 10:08 AM
Re: Cannot connect internet to Sky q box. The internet is working on other devices. Sky mini won’t w
Hi @Frazpot
