Discussion topic: Cancelling part of a package under contract
Message posted on 18 Nov 2025 02:52 PM
Having just been widowed I am trying to cut down on expenses so want to cancel the sports part of my package , contract ends 2027 .Is this possible ?
Message posted on 18 Nov 2025 02:54 PM
Re: Cancelling part of a package under contract
Sorry for your loss.
To remove part of your TV package you need to contact Sky giving the standard 31 days notice. If you have 'in contract' discounts you may not be able to remove them. Also make sure cancellation of a certain add-on doesn’t cancel another part of a discount.
You may be able to remove it via this link which includes a message option (usually available between 9am & 7.30pm) or by calling in using the number that will appear.
https://www.sky.com/help/articles/change-your-package-2-t2#downgrade
Additionally, are you the account holder or was it your partner?
Message posted on 18 Nov 2025 02:55 PM
I am the account holder .
Message posted on 18 Nov 2025 02:57 PM
Okay. Try the method above, if not give Sky a call, explain your bereavement and hope for a sympathetic ear.
Message posted on 18 Nov 2025 03:57 PM
Does anyone have a direct number for cancellations on sky ?
Message posted on 18 Nov 2025 03:58 PM - last edited: 18 Nov 2025 04:00 PM
There is a number on that link in the earlier thread. Otherwise call Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline if you have Sky Broadband. The forum doesn’t allow the display of other numbers. Other official numbers to Sky from the UK are 03 numbers which are normally inclusive from non Sky phones.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Message posted on 18 Nov 2025 03:59 PM
@Gail67 wrote:Does anyone have a direct number for cancellations on sky ?
Use the link in post #2. It gives you Sky's CS number.
