Discussion topic: Cancelled multi screen and now the mini box has gone off but no signal cable to plug the skyq into.
Message posted on 17 Nov 2025 09:18 PM
Multi screen has been cancelled and the box has gone off but we don't have a signal cable...sky cable in the other room to plug the skyq box into it just an outside Ariel. Do we need an engineer
Message posted on 17 Nov 2025 09:22 PM
Re: Cancelled multi screen and now the mini box has gone off but no signal cable to plug the skyq in
@Elisha14 If you mean the HDMI cable why no use the one from the mini?
Other than that all other cables such as power & satellite must already be in place for the mini Q to have run from the main Q box.
Message posted on 17 Nov 2025 09:24 PM
The satellite cable is in another room that is connected to the sky q box the mini is in a different room which is connected via a HDMI cable to the TV. The sky q box needs moving and there is no satellite cable in the other room available
Message posted on 17 Nov 2025 09:34 PM
The main Q box needs connecting to satellite cables.
If the cables are not in the correct location then you need to pay to have them moved. Sky charge around £65 I believe.
Message posted on 18 Nov 2025 05:30 AM
Your post and thread title are a bit confusing. The thread title states 'Cancelled multiscreen and now the mini box has gone off but no signal cable to plug the Sky Q into'
If you've cancelled Multiscreen then the mini box needs to be returned to Sky and obviously won't work.
Message posted on 18 Nov 2025 07:30 AM
I'm wondering if the OP had Multiroom, cancelled it, but now wants the Main Box in the room that previously had the Multiroom Box, which obviously doesn't have the satellite cables in it.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
