Discussion topic: Cancelled Sky and I now cannot get a freeview or freesat signal
Message posted on 24 Mar 2023 07:30 PM
Message posted on 24 Mar 2023 07:33 PM
							Re: Cancelled Sky and I now cannot get a freeview or freesat signal
@Guitar1234 wrote:
I have been told this is the fault of sky, can you please tell me how to fix this.
Freeview comes via an aerial so is definitely not Sky's fault.
Freesat does work but you need to buy the correct freesat box that supports the LNB.
Message posted on 24 Mar 2023 07:37 PM
@Guitar1234Unless you have a 4K Freesat box or pay someone to change the LNB in your dish it will not work.
Message posted on 24 Mar 2023 07:43 PM - last edited: 24 Mar 2023 08:17 PM
The LNB (receiver module) currently on your satellite dish will be one which is compatible with a main Sky Q box (and 'Freesat 4K' branded hardware) but not an HD Freesat receiver: it would have to be replaced for such a box to work, but Sky will not do this for you.
As noted above, Freeview is digital terrestrial television broadcast from a local mast and received through an aerial: it has nothing to do with a satellite dish.
