Discussion topic: Cancel discovery + sky say I can't disconnect my account through them discovery + say the same help
Message posted on 06 Jan 2025 06:08 PM
Message posted on 06 Jan 2025 07:44 PM
Re: Cancel discovery + sky say I can't disconnect my account through them discovery + say the same h
For Sky Q - Press Home on your Sky remote, then select My Sky at the bottom of the screen.
You’ll then see a screen with your purchases. Select Your products. You’ll then be asked to enter your Sky TV PIN number.
Then follow the prompts to cancel.
In the Mysky app on a phone or tablet.
Go to the TV section, then My Bill section, there will be a section listed Marketplace, under that click on View subscriptions.
You should be able to cancel it there.
Message posted on 06 Jan 2025 09:05 PM
The problem is it's part of the sky ultimate package so you would need to cancel the whole pack not just discovery +
Message posted on 02 Nov 2025 02:44 PM
Hi CaesaromeI trust you are well and good.. I am tryiing to cancel the 4 week free sky cinema but when I get to the actuall product active section there is no cancel subscription option, same on my mobile mysky app? Any suggestions please? Many thanks. H🙄
Message posted on 03 Nov 2025 08:23 PM
@Henry+the+eigth afraid you will need to call Sky
LG 49SJ 810 V UHD TV, Google Pixel 10 Pro XL mobile
