Discussion topic: Can you transfer recordings from a faulty sky Q box to a new sky Q box?
This message was authored by: keith+pattison
 Hi,
My sky Q box keeps going faulty and i keep having to reset it.
The problem is that i have saved recordings on its hard drive from
years ago that i do not want to loose!
If i get a replacement Q box is there any way to transfer my saved
recordings?
As i assume that cannot be done, i am putting up with a faulty Q box.
thanks
Keith
Re: Can you transfer recordings from a faulty sky Q box to a new sky Q box?
@keith+pattison wrote:
 Hi,
recordings?
thanks
Keith
No way unfortunately to transfer recordings @keith+pattison
Buy and keep from Sky Store can be re downloaded to another box but not recordings
@keith+pattison
As you've guessed it can't be done I'm afraid. Sky Q boxes are not designed for long term storage.
