Discussion topic: Can the sky q box go behind the tv in a media wall?
Message posted on 07 Jun 2023 07:54 PM
Can the sky q box be mounted behind the tv in a media wall and still be operated by remote control?
Message posted on 07 Jun 2023 08:09 PM - last edited: 07 Jun 2023 08:10 PM
Re: Can the sky q box go behind the tv in a media wall?
hi @J+Dent
Remote wise generally not a problem as the bluetooth connection is extremely good (I have controlled my box from my rear garden - so through 2 walls & 2 rooms.)
That said if you need to reset it for any reason the remote initially needs line of sight
Otherwise - obviously you must be able to cable up and if needed maintain wifi which could be a problem if enclosed.
The key thing is to ensure good ventilation & the main box should not really be mounted vertically if that is what you are considering
Message posted on 07 Jun 2023 08:11 PM
@J+DentYes as the controller is bluetooth it will work BUT the Q boxes easily overheat so make sure there is plenty of air circulation, also make sure you can get to the mains switch in case you need to do a reset.
Message posted on 07 Jun 2023 09:33 PM
Thanks both
i was intending on ensuring I can access it by pulling tv out of media wall on bracket
i will have to think about how to Not mount vertically (was looking at a bracket for that) but hopefully there would be enough air flow
