Discussion topic: Can’t watch uhd movies in sky cinema
This message was authored by: bagpuss1968
Get the message SORRY , THERE ARE NO PROGRAMMES OF THIS TYPE AVAILABLE  when I try to select one
Re: Can’t watch uhd movies in sky cinema
Hi @bagpuss1968
Have you tried rebooting your Q box?
Avatar for bagpuss1968
Hi oldfella
thanks for your reply, yesI have already tried rebooting the sky Q main box and my router (I don't have sky broadband ) but nothing seems to have changed still get the message it also seems to be any on demand uhd programs not just cinema
@bagpuss1968 wrote:
Hi oldfella
Assume you have the monthly Q UHD subscription @bagpuss1968 .
Also is your Q box resolution set to 2160p ?
Just checked they are changing me for uhd and the box is set to the 2160 uhd setting
OK @bagpuss1968
In the Q box Home menu
Home - Settings - Status
is the Network connection shown ticked?
If you have Sky Sports;   can you watch the UHD Sports channels?
Yes  live sports in uhd is working fine it's just on demand programs
What about the Network connection in Status. @bagpuss1968 ??
Everything is connected just trying to update the system software
