Discussion topic: Can’t rewind or pause. Also recording not showing
This message was authored by: Babsy1
Watching programme that is recording but no red light for recording.  Message on screen says can't rewind or pause.  The above is also on another channel
Re: Can’t rewind or pause. Also recording not showing
@Babsy1 Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Hi @Babsy1
You may have a hard drive issue.  If you cannot watch existing recordings work through the following link
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
