3
This discussion topic has been answered Discussion topic: Can't remember my pin, gone through all sky help tells me to put in my sky pin etc don't know it
This message was authored by: Trevgreen
Can't remember my pin, gone through all sky help tells me to put in my sky pin etc don't know it. Phone numbers are all inaccessible
Re: Can't remember my pin, gone through all sky help tells me to put in my sky pin etc don't know it
@Trevgreen
Unless you have changed it,  your pin number is usually the last 4 digits of your viewing card number. You can find your viewing card number in Home > Settings > System info.
@Trevgreen
@Trevgreen  If you have never changed the pin it's normally the last four digits of your viewing card number
@Daniel0210 wrote:
@Trevgreen
Should that fail @Trevgreen
then go to Home - Help & there should be a 'Reset PIN'  option - IIRC you will need to know the  account number you use for billing
