This discussion topic has been answered Discussion topic: Can't remember my pin, gone through all sky help tells me to put in my sky pin etc don't know it
Message posted on 07 May 2024 12:36 PM
Message posted on 07 May 2024 12:39 PM
Unless you have changed it, your pin number is usually the last 4 digits of your viewing card number. You can find your viewing card number in Home > Settings > System info.
Re: Can't remember my pin, gone through all sky help tells me to put in my sky pin etc don't know it
@Trevgreen If you have never changed the pin it's normally the last four digits of your viewing card number
Message posted on 07 May 2024 12:41 PM - last edited: 07 May 2024 12:45 PM
Should that fail @Trevgreen
then go to Home - Help & there should be a 'Reset PIN' option - IIRC you will need to know the account number you use for billing
