Discussion topic: Can’t play recorded programmes no satellite signal message
This message was authored by: Janice13
Can't play back recorded programmes problem with satellite signal message
Re: Can’t play recorded programmes no satellite signal message
Hi @Janice13
First try rebooting your Q box.
If you still have a No Satellite signal message
Work through the following link and if you cannot solve your issue it will lead to booking a Engineer.
Alternately, if you are on a Communal Dish you will need to contact your Landlord or Management company.
@Janice13
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
PS - your two duplicate post/thread have been removed.
