Discussion topic: Can’t pair my skyQ remote to sharp aquos tv
Message posted on 04 Nov 2023 10:09 AM
Does anyone know how to pair a Sharp Aquos TV to a Sky Q remote as I have tried all the codes pre suggested to no avail? Thanks in advance for any help
Message posted on 04 Nov 2023 10:15 AM - last edited: 04 Nov 2023 10:22 AM
							Re: Can’t pair my skyQ remote to sharp aquos tv
Hi @Mando99
I believe that if you check you will find that your Sharp TV remote uses RF (radio Frequency) and not Infrared.
If so you will not be able to pair the Q remote.
Edit
You can check if your TV remote is RF by completely cupping your hand round the top of the remote.   If it is RF (or Bluetooth) it will still operate the TV.
If it is infrared your hand will block the signal and it will not operate the TV
Message posted on 04 Nov 2023 10:29 AM
Message posted on 08 Nov 2023 07:16 PM
Hi @oldfella
You were indeed correct the sharp aquos remote is RF so I appreciate the help with sorting my query
Message posted on 13 Jun 2024 06:31 PM
I cannot get the Sky Q remote to operate the volume on my sharp aquos tv. I did the hand cupped around the remote to check if it's RF but it doesn't seem to be because it doesn't do anything when i cup the front of the remote. So what are any other suggestions for getting the volume control to work. Everything else works and is paired just not the volume controls
