5
This discussion topic has been answered Discussion topic: Can’t pair TCL 50_PF650K tv
This message was authored by: Dave409
Hi everyone- hoping someone can help. I've tried pairing my TCL 50_PF650K to the Sky Q box but it's just not happening, I've followed the instructions by the letter, it's hopeless. The tv is brand new so I thought there would be no problems at all, the model number isn't available on the Sky Q instructions. At the end, SKY Q don't give me any possibilities with alternatives to match my tv. ....
This message was authored by: Laing1 Answer
Re: Can’t pair TCL 50_PF650K tv
@Dave409 If you have tried all the options it gives you under TCL in case one of the other models work for your TV  I have 2 suggestions try under the other brands option or try under vestel
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
TCL is a gigantic Chinese corporation and manufactures on a huge scale: I suspect they won't be rebadging Turkish television sets.
Avatar for Dave409
Thank you so much ☺️, I used Vestel and it worked straight away xx
No but might well use some of the same electronics.
This message was authored by: Afromama
Thanks, it works on Vestel #1
