Discussion topic: Can’t get viewing card into replacement Sky Q box
This message was authored by: John+Carver
Hi...my old SkyQ box died with the dreaded hard disc failure.  A new one arrived today...very efficient... but the viewing card simply won't go in.  It goes in half way and meets a dead stop.  I've been with Sky for nearly 30 years and I can't believe I'm doing something really stupid.  Anyone got any ideas or I'll have to get another box!
Re: Can’t get viewing card into replacement Sky Q box
Not a lot you can do @John+Carver
I assume you have tried to have a look into the card slot with a torch to see if you can spot any restrictions.  Not much room to see anything I know.
If you have not found any issues as described in post above.
You will need to follow the advice here and book a service visit
https://www.sky.com/help/articles/viewing-card-wont-click
