Discussion topic: Can’t get tv connected to WiFi
This message was authored by Doc906 This message was authored by: Doc906
Tv is stating we don't have internet connection and nothing we do works.
Doc906
Re: Can’t get tv connected to WiFi
Is anyone there?
Hi @Doc906
Patience is a virtue.
Try a Network Reset found in Q box Home - Settings - Setup - Network.
This message was authored by Laing1 This message was authored by: Laing1
@Doc906 wrote:
Is anyone there?
@Doc906 just so you are aware  you are not contacting Sky's customer services on here, this is a customer to customer forum where customers help each other.
