15 Feb 2024 11:45 AM
Tv is stating we don't have internet connection and nothing we do works.
15 Feb 2024 11:49 AM
Is anyone there?
15 Feb 2024 11:51 AM
Hi @Doc906
Patience is a virtue.
Try a Network Reset found in Q box Home - Settings - Setup - Network.
15 Feb 2024 03:30 PM
@Doc906 wrote:
Is anyone there?
@Doc906 just so you are aware you are not contacting Sky's customer services on here, this is a customer to customer forum where customers help each other.
