1
This discussion topic has been answered Discussion topic: Can’t get past step 1 of 4 on setup following a power cut. Main box fine, issue with the second room
This message was authored by: Richardfermont
Just had a power cut. Rebooting box remote did not work, but still works to and red light comes on when pressing ? Pressed the button on the box and screen says "step 1 of 4, press (centre dot) to continue. However nothing happens when I try this.
Re: Can’t get past step 1 of 4 on setup following a power cut. Main box fine, issue with the second
Hi @Richardfermont
Reset your mini remote by pressing  and holding 7 & 9 together on the remote until it’s led flashes four times.
This will set it to infrared which will work all Q boxes.   However the remote must be pointed directly at the mini box.
Switch your mini box back on and you then you should be able to get past step 1 of 4.
Once you get the mini working make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
Hi @Richardfermont
