Discussion topic: Can’t get no tv programs on my tv it says waiting tv schedule
This message was authored by: Darren+Field-thom
Cannot get tv channels on my tv it says awaiting tv schedule
Re: Can’t get no tv programs on my tv it says waiting tv schedule
@Darren+Field-thom
Firstly reboot your router. Then try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
▪️I AM NOT A SKY EMPLOYEE ▪️
