Discussion topic: Can’t get my sky box to work
Message posted on 07 May 2024 12:55 PM
Need engineer to pop in take a look and hopefully fix connection between mini box and tv
Message posted on 07 May 2024 01:43 PM
Re: Can’t get my sky box to work
The only connection between your Mini box and your TV is an HDMI cable. Just make sure it's securely pushed in at both ends.
Message posted on 07 May 2024 02:03 PM
Reboot the mini as above.
Message posted on 17 Jan 2025 05:48 PM
Cannot access sky box settings
Message posted on 17 Jan 2025 05:50 PM
@Binky_Boy_23 wrote:Cannot access sky box settings
You may have to give just a little more detail to get some help...
Why not?
