Discussion topic: Can’t get box to connect to wifi
Message posted on 05 Jun 2023 08:50 PM
Can't get Wi-Fi to connect to qbox
Message posted on 05 Jun 2023 09:00 PM
Re: Can’t get box to connect to wifi
Hi @Wfhworker
Have you carried out a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
