		Discussion topic: Can’t get any response from sky remote control and sky q box
	This message was authored by: Jamesconnor101
		Message posted on 06 Sep 2023 09:25 PM
Can't get any response from sky remote control and sky q box
Find out more
		Message posted on 06 Sep 2023 09:27 PM
							Re: Can’t get any response from sky remote control and sky q box
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
