Discussion topic: Can’t connect to router
This message was authored by: sferri
Can't connect WiFi
Re: Can’t connect to router
@sferri wrote:
Can't connect WiFi
Hi @sferri Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on?.
