Discussion topic: Can’t connect to Sky Q mini box
Message posted on 03 Jun 2023 05:40 PM
I can't connect to Sky Q mini box
Message posted on 03 Jun 2023 05:44 PM
Re: Can’t connect to Sky Q mini box
Hi @K.+Kulendra
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
