Discussion topic: Can’t connect to 5g only 2.4
This message was authored by: Andy226
Had super fast fiber fitted and can only connect to 2.4g sky w won't find 5g and the 2.4 struggles to download and playback
Re: Can’t connect to 5g only 2.4
hi @Andy226
If your provider is not SKY then, yes, it will only connect on 2.4Ghz wifi
Are you able to connect the main box to the router via ethernet ?
Avatar for Andy226
Why is that do you know
This message was authored by: ddiamondblue
Probably because Sky don't want to reward you for using non-sky products!
Wired ethernet will probably get the most out of your super fast broadband
I think it's more likely that the boxes generate their own 5GHz network.  (Although some see it as 'punishment')
Regardless, the bandwidth on 2.4GHz is more than sufficient to run the box.  (And that band generally carries further)
