Discussion topic: Can’t connect sky q box to new sky gigafast router
This message was authored by: DBowen
I can't find the WPS button on the new router to connect tv & internet
Re: Can’t connect sky q box to new sky gigafast router
Hi @DBowen
If you have the new Sky Max router then Unfortunately these act like a 3rd party router when used with the Q box.
This means that you have to connect it to your Q box using SSID and password (for the 2.4 Ghz band) and not WPS.
Try resetting the connection again.
If the Sky Max router has a Reset on the back of the hold it until the power until  light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
If it  does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
On Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
