Discussion topic: Can’t connect my q box to router
This message was authored by: gogzee1971
Tried to connect multiple times using wps
even entered password of router still no connection
Re: Can’t connect my q box to router
Hi @gogzee1971
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
