Discussion topic: Can’t connect my mini box
This message was authored by: TB40
My mini box won't connect to my sky Q I have wi fi
Re: Can’t connect my mini box
Hi @TB40
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
