2
This discussion topic has been answered Discussion topic: Can’t connect Sky Q to the router
This message was authored by: IanHolland
I can't connect my Sky Q box to the router, internet works ok for everything else. It did connect beforehand but won't now
Re: Can’t connect Sky Q to the router
Hi @IanHolland
If on Sky broadband first reset your broadband router by holding Reset on the back until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
Hi @IanHolland
Avatar for IanHolland
Level 0 icon
Thanks 👍
