Discussion topic: Can't activate software update with my controller. But if I switch off and restart it overloads and
This message was authored by: DF16
The screen shows that I need to activate a software update. But the box on the screen does not activate the update when I press the controller. If I then switch off and restart then I can enter and use everything as normal. I have tried entering downloads via settings but that does not work and the software download update message is still there the next time I switch on..
Re: Can't activate software update with my controller. But if I switch off and restart it overloads
I suspect it's your TV asking for the update and not Sky Q...
Hi @DF16   Use your TV remote.
Avatar for DF16
Thanks PandJ 2020 problem solved.
Avatar for DF16
