Discussion topic: Can not select 001 on settings to sort our hard disc errror
Message posted on 21 Jul 2024 06:53 PM
Trying to reset the hard drive but all the information says to select 001 on settings but does not do anything when I am doing this
Message posted on 21 Jul 2024 06:57 PM
							Re: Can not select 001 on settings to sort our hard disc errror
Press the Home button on your Sky Q remote. Scroll down to Settings.Don't press select. Using the numbers on the remote enter 001 then Select to display the engineer menu.
Hover on settings, hit 0-0-1 then press select.
But the hard drive error may be fatal and you'll need to call Sky for a replacement box.
Remember to remove your viewing card...
