Discussion topic: Can not pair sky remote with Panasonic TX-32MS490B
Message posted on 09 Nov 2023 03:07 PM
Tried process and all suggested codes and does not work. Also factory reset remote and trued again.
Message posted on 09 Nov 2023 04:15 PM
Re: Can not pair sky remote with Panasonic TX-32MS490B
Try First rebooting the Q box @philby60
Then with the Q box and TV on trybcompletly resetting your Bluetooth remote again.
