Discussion topic: Can not get a satatite signal
This message was authored by: COLI3
I have scaffold up and it's blocking my disc signal, can I get Sky by using my Skybox via broadband or WiFi?
Re: Can not get a satatite signal
No, but you can use Sky Go if you have a subscription.
@COLI3
Depending on how long the scaffolding will be up for the Sky Q box will require periodic connection otherwise will eventually stop.
