4
This discussion topic has been answered Discussion topic: Can i link my dish wirelessly to my sky q box
This message was authored by: Mff1962
Can I connect my sky dish wirelessly to my sky q box
Re: Can i link my dish wirelessly to my sky q box
@Mff1962
No, that technology does not exist.
In rare cases Q subscribers have the main Q box on the end of a cable from the dish but running as a concealed unit without a television set attached, and then use Q Mini boxes over WiFi for television viewing.
@Mff1962
It has to be via cables.
@Mff1962
Hi @Mff1962
Bear in mind that Sky Stream works without a dish and is purely internet driven.
However if you are used to Sky Q then Sky stream may not suit you but worth research.
Main downside of stream is that there is not any recording facility
https://www.sky.com/help/articles/sky-stream-faqs
Avatar for Mff1962
Level 0 icon
Cheers, I'm moving my TV from one wall to the opposite side of the room, so I'll have run a longer cable
