Discussion topic: Can i just unplug my mini box and move it to a dirrerent room?
Message posted on 11 Jul 2024 08:37 PM
Message posted on 11 Jul 2024 08:39 PM
							Re: Can i just unplug my mini box and move it to a dirrerent room?
hi @Deanzzz
Yes - although it does work on wifi so depends on the coverage of your wifi if SKY or on the wifi generated by the main box if other provider
Message posted on 11 Jul 2024 08:41 PM
The new room is closer to the BT router and sky main box so assume that will be ok? And I am OK moving it back to the other room when I'm done?
Message posted on 11 Jul 2024 08:43 PM
@Deanzzz Yes it should be OK then - as you are with BT then it doesn't matter how near the router just your Mian box & no problem moving it back
Message posted on 11 Jul 2024 08:44 PM
Hi @Deanzzz You can move it backwards and forwards to any room you like as long as it is close to the Main box.
