Discussion topic: Can anyone help to get my moms sky working
Message posted on 23 Oct 2024 06:00 PM
General gist of what has gone on, lighting strike couple weeks ago blew out the the hub on phone.Openreach came out said they need a new phone base unit & also needed a new router from BT, got the new base unit got the new router logged most of the tech downstairs with new password. I got the phone working yesterday with help from chap over the phone Upstairs they have a tv with a Q mini box attached. Hasn't already linked with the main box. Getting free view on it but nothing for sky except a banner saying no signal. Anyone got any ideas? any help would be much appreciated I am at a loss.
Message posted on 23 Oct 2024 06:21 PM
Re: Can anyone help to get my moms sky working
Hi @hoopla66
Assuming the main Q box is working OK
,First try rebooting the main Q box and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
Message posted on 23 Oct 2024 06:43 PM
Think it was working fine until we put new router in place. Thanks for your input she can cope with free view for a day longer, 2 of us needed to reboot both boxes. Will pass info onto her I will try reboot on Friday. Once again many thanks.
Message posted on 23 Oct 2024 07:41 PM
hi @hoopla66
If the main Q box isn't working
On 3rd party broadband and your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
On 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
This should get the main Q box working.
Then use the instructions in my first post to connect the mini
