This discussion topic has been answered Discussion topic: Can SkyQ box be connected to TV that does not have HDMI?
Message posted on 09 Aug 2024 02:09 PM
Hi,
I have an old, but perfectly fine Sony Bravia Tv with SCART access connected to a Sky HD box and no HDMI port. Sky have advised me that their HD box will no longer receive software updates and are offering to replace the HD box with a SkyQ box, but as I haven't got a HDMI port, is this possible.?
I don't want to have to buy a new Tv simply because they are basically discontinuing the HD box. Can anyone advise if there is an adapter to change the scart socket on my tv, to a HDMI port that can then take the newer SkyQ box?
Message posted on 09 Aug 2024 02:23 PM
You can buy an HDMI to Scart adapter from a variety of online stores or shops like Curry's, but I think the problem you might face is finding one that is HDCP compliant, which is the HDMI security used between the box and TV to protect it from being copied.
LG B6 OLED 55” | LG UP75 LCD 43” | sky Q | sky Q Mini | SONOS Beam 2 | Apple TV 4K | EE Full Works FTTC
Message posted on 09 Aug 2024 02:24 PM - last edited: 09 Aug 2024 02:27 PM
Re: Can SkyQ box be connected to TV that does not have HDMI?
Note that the absence of software updates is frankly a marketing red herring: your Sky+ HD box will continue to operate as it does now, probably until satellite television ceases to be a thing. There are no 'updates' which will bring it additional functionality, and the operating system is mature enough to no longer require patching.
Message posted on 09 Aug 2024 02:29 PM
Sky+HD boxes aren't being discontinued. They'll continue to operate for the foreseeable future, though some of the more peripheral services, like the interactive service, and red button services have been withdrawn. The life of your Sky+HD box is likely to be limited only as a result of hard disk failure, so there's no immediate rush to switch to Sky Q.
All that said, there are HDMI to scart converters available, if you wish, some more successful than others. Make sure you find one the right way round, i.e. HDMI from signal source to a scart TV. They're not interchangeable,.
Message posted on 09 Aug 2024 02:35 PM
hi @Judibj
As the others have said the lack of software upgrades will not cause your HD box to cease to function.
You may , also, wish to read some notes I have made for people considering switching from SKY +/HD to SKY Q
Message posted on 09 Aug 2024 03:40 PM
Many thanks to all of you who took the time and trouble to respond to my questions. I remember a visit from a Sky engineer who told me a couple of years ago NOT to upgrade to SkyQ if it was offered, as my tv was unsuitable for it, so I was concerned I was going to lose my viewing capabilities. When I contacted Sky about it, they basically tried to sell me the Sky Glass tv set up, so that I wouldn't need the SkyQ upgrade at all. BUT.....as a result of your posts, I've queried Sky about needing to change the Sky+ box at all, and you are right, the box will continue as normal, until it fails at some indeterminate future date. So, on reflection, I will stay with the equipment I've got until either the Sky+ box or my trusty TV fails, at which time I can look then, at upgrading either or both. Thank you all once again for your advice.
