Discussion topic: Can SKY Q work only on Wi-Fi?
Message posted on 11 Apr 2024 12:50 PM
Hi,
I'm sure this has been asked before, but can't find the post.
Want to move my TV/SKY Q box to a different location in the same and don't want to run the satalitte cable to the new location.
Can SKY Q work only on WiFi only?
Any other suggestions if not?
Message posted on 11 Apr 2024 12:53 PM - last edited: 11 Apr 2024 01:02 PM
Re: Can SKY Q work only on Wi-Fi?
@Helsop wrote:
Hi,
Hi @Helsop
Afraid the main Q box needs connecting to the twin cables from the dish.
Edit.
One option is keep the main Q box connected to the dish at its current location and use a Sky Q mini at the new location which should work on WiFiif it is range.
You need the Sky Q Monthly Multiscreen to use a mini and bear in mind that minis are not UHD capable.
Message posted on 11 Apr 2024 01:00 PM
Thanks, was expecting that answer, but always hopeful!
Message posted on 11 Apr 2024 01:16 PM
The 'Wifi only' television product from Sky is Glass/Stream
