Discussion topic: Can I swap a sky Q box for a sky HD box?
Message posted on 13 Sep 2024 07:14 PM
Can i swap a sky q box for a sky hd box?
Message posted on 13 Sep 2024 07:16 PM
Re: Can I swap a sky Q box for a sky HD box?
Message posted on 13 Sep 2024 07:19 PM
I have canceled my sky tv account and they are wanting the old box box so I brought a older sky hd box to use as a freesat box, is there anyway of using it
Message posted on 13 Sep 2024 07:20 PM - last edited: 13 Sep 2024 07:23 PM
Message posted on 13 Sep 2024 07:22 PM
hi @Jet1987
The only way to use an old HD box is to get the LNB (the electronic bit on the dish) changed back to a 'Universal' LNB
BTW THe latest 4K Freesat boxes can work with the Wideband LNB that SKY Q uses
Message posted on 14 Sep 2024 08:49 PM
I have tryed the sky HD box in my bedroom where there is currently a free sat box and the sky hd box works there, seems strange that it was there but not where the sky q box is??
Message posted on 14 Sep 2024 08:56 PM
Where customers had Freesat boxes SKY would sometimes install what is called a Hybrid LNB which has 2 sets of outputs - wideband for use with SKY Q & Universal outputs for Freesat.
Message posted on 14 Sep 2024 10:53 PM
@Jet1987 wrote:I have tryed the sky HD box in my bedroom where there is currently a free sat box and the sky hd box works there, seems strange that it was there but not where the sky q box is??
Not at all, that's exactly what I'd expect. Must have a separate connection coming off a hybrid LNB to that box, as above.
Message posted on 15 Sep 2024 06:26 PM
How do I get this to work in the living room now where the sky q box is please?
thanks
Message posted on 15 Sep 2024 06:47 PM
thanks
You mention that a freesat box works in another room so it depends if you want to keep that working.
If you don't then switching the connectiions over at the LNB should work.
I suspect, however, you want that to keep working.
If this is the case you probably have 2 options.
1) Forget the 2nd hand SKY HD box and get a Freesat 4K box which works with the wideband outputs as used by SKY Q
or
2) Get the LNB changed for another with all 'Universal' outputs
