This discussion topic has been answered Discussion topic: Can I put my sky box in a cupboard?
Message posted on 11 Nov 2023 02:24 AM
Hi there
im thinking about storing the box in cabinets next to the fireplace but wondered whether the sky q remote will still work. I've read conflicting opinions on this. Is it Bluetooth controlled? Does it also have infra red? I read that while it's Bluetooth the IR still does the sound!! So confused. It's a remote with the blue button.
many thanks
Message posted on 11 Nov 2023 07:33 AM
@Laura341 wrote:Hi there
many thanks
Hi @Laura341 the most important thing is whether the cabinet allows for adequate ventilation for the Sky Q box
The Sky Q remote will operate the Sky Q box whilst in a cupboard/cabinet as bluetooth doesn't need line of sight
But like I said your Sky Q box needs plenty of ventilation as it can easily overheat.
many thanks
Message posted on 11 Nov 2023 08:17 AM
Re: Can I put my sky box in a cupboard?
With the risk of overheating mentioned already, placing it in cupboards next to a fireplace might not be the best positioning.
Message posted on 11 Nov 2023 08:20 AM
@Daniel0210 wrote:With the risk of overheating mentioned already, placing it in cupboards next to a fireplace might not be the best positioning.
My thoughts exactly. Cupboard elsewhere maybe.
Message posted on 11 Nov 2023 08:42 AM
@Laura341 In terms of the IR controlling the sound, that's controlling the volume on your actual TV.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 11 Nov 2023 09:29 AM
Thanks so much for your responses. It's a fireplace but has no fire in it. But still there isn't really any ventilation in the cupboard so that's something I will have to think about. Thanks again for your help
Message posted on 11 Nov 2023 10:54 AM
Sky Q boxes use materials that can cope with the normal heat generated but you should always be able to place the palm of your hand on top of the box and not have to immediately lift it off.
Message posted on 11 Nov 2023 05:24 PM
Ok thank you I'll make sure it has space around it and see how it goes. Thanks again
