Discussion topic: Can I mix a remote via Ethernet with one via Wi-Fi
This message was authored by: NewToSky
My brother has constant disconnects on one of his Sky remotes . His other via Wi-Fi works fine. If I were to connect the problem remote box via Ethernet over powerlan would the Q box be able to cope or is it one way or another?  Many thanks.
Re: Can I mix a remote via Ethernet with one via Wi-Fi
Hi @NewToSky   Yes, try connecting your Sky Mini box to the Main Sky Q box using powerline adapters. That should work. Of course it depends on your mains electricity infrastructure.
