This discussion topic has been answered Discussion topic: Can I have the SkyQ box in a cupboard and still control it? Maybe by using a magic eye?
Message posted on 22 May 2023 05:34 PM
Want to put Q box in a cupboard. Can I still use the remote?
Message posted on 22 May 2023 05:47 PM - last edited: 22 May 2023 05:49 PM
All Q Voice Control remotes work over Bluetooth, and so function as long as the box is in wireless range (and not in a Faraday Cage) : they don't need line of sight. An IR repeater would be valid for the infra-red only (non-Voice) remotes which used to ship with Mini boxes and v1 1TB main boxes (before 2020).
Message posted on 22 May 2023 05:47 PM - last edited: 22 May 2023 05:48 PM
Re: Can I have the SkyQ box in a cupboard and still control it? Maybe by using a magic eye?
hi @Peterc38
All voice remotes that can be used with all boxes use bluetooth which does not need line of sight - mine is on a shelf behind my TV.
So remote wise not a problem
The key thing, however, is to make sure there is sufficient ventilation & if using wifi rather than ethernet then this may be compromised
Message posted on 22 May 2023 07:56 PM
Thanks to both of you. I'll give it a go
Message posted on 23 May 2023 04:34 PM
Can confirm YES this is what I do.
Just a note though, I had to connect a new remote a while back, but to do that you need clear line of sight to the IR receiver on the box while doing that.
