8
This discussion topic has been answered Discussion topic: Can I buy extension wires to move tv and box to other side of room
This message was authored by: Khulme
I want to move tv to other side of room and my wires won't reach can I buy wires to connect
Re: Can I buy extension wires to move tv and box to other side of room
Hi @Khulme
Just look for Satellite Extension cables.
Just bear in mind that you need two cables with the necessary two F connector fittings..
Some come as as a pair or as a twin (shotgun) cable and include the two female F connectors.   However some are single cables where you need two.
https://www.amazon.co.uk/YCAB03M-Satellite-Extension-Compression-Connectors-White/dp/B00627R8T6/ref=...
Hi @Khulme
Avatar for Khulme
Thank you for that I just rang sky they want £60 for engineer to come out
This message was authored by: P77
You can do this yourself, I did mine a few months ago... Bought the cables off Amazon and move the sky Q box to the other side of the living room.. Works perfectly..
This message was authored by: Fannyshmeler
Could you please tell me the name of the extension cable and connector needed, from Amazon
thankyou
The brand was SSM
SSL Satellites 10Meter  Twin satellite shotgun cable extension kit..
This message was authored by: nyree15
Is that cable in the link able to connect straight to the cables from the wall then into the back of the sky box?
@nyree15
That's what it's intended to do.
This message was authored by: Louise176
Can you tell me what you bought to do this please
