This discussion topic has been answered Discussion topic: Can I buy an extension lead to fit between my sky dish and my sky q box????
Message posted on 09 Jan 2024 02:59 PM
I'm moving the Sky Q box in a room, and I'll need to get an extnsion lead to make the cables longer. Can anyone suggest a good one that doesn't caue any interference?
Thank you.
Message posted on 09 Jan 2024 03:01 PM
@keithrees1964 wrote:I'm moving the Sky Q box in a room, and I'll need to get an extnsion lead to make the cables longer. Can anyone suggest a good one that doesn't caue any interference?
Thank you.
Something like this will work perfectly well.
Thank you.
Message posted on 09 Jan 2024 03:20 PM
Re: Can I buy an extension lead to fit between my sky dish and my sky q box????
Many thanks.
Message posted on 09 Jan 2024 05:31 PM
Note that lengthening a cable will always increase attenuation of the satellite signal because that's a fundamental principle of physics. A small percentage increase on the original length shouldn't be significant.
